Minneapolis Moline Tractors Discussion Forum
1950 uts electrical problem
KPL
10-12-2004 19:10:32
I have a 1950 UTS. Is this a positive ground? Can it be changed to negative ground. I cant get the starter to spin. When i short the solinoid it just clicks. Does anyone have a wiring diagram? Thanks for the help. KPL
deadeye
10-15-2004 12:22:09
 Re: 1950 uts electrical problem in reply to KPL, 10-12-2004 19:10:32
Just take the starter off and see if it works wired with a set of jumper cables laying on the floor. Make sure you put your foot on top of it as they do have a little power to them. They will also bind a little when inserted into the mounting hole to the flywheel. Make sure it is free and not in a bind. Then check the Solinoid as they are usually the culprate. Just take the old one off and put a new one on. I convert all of my units to 12 volt. The only things I change are the coil, generator to an alternator, and switch the wires at the amp gauge. Starter and solinoid stay 6 volt. Good luck....deadeye
KPL
10-16-2004 21:40:28
 Re: 1950 uts electrical problem in reply to deadeye, 10-15-2004 12:22:09
Thanks for the help guys. I got the starter to crank now. It fired up and then died, and then no fire. I am thinking plug wires and points. Didn't have time to check it tonight. One other thing, the front set of cylinders have a champion D21 plug in them, and the rear set have champion J8C in them. Has someone changed one of the blocks on it? If so which one is the correct one? Does anyone know what the other block may have come off of? (just for my curiosity) Thanks for any help.
Kelvin
10-13-2004 15:38:05
If you are getting a bunch of quick clicks at the solenoid, there is either a weak battery, a bad connection (Check where the pos cable grounds to the transmission as well as the other places) OR you may have a 12v solenoid trying to work on 6v.
Switching polarity shouldn't make a difference, unless in doing so you happen to fix the bad connection.
KPL
10-13-2004 21:09:33
 Re: 1950 uts electrical problem in reply to Kelvin, 10-13-2004 15:38:05
Thanks for the help. I will give it a try.
