Minneapolis Moline Tractors Discussion Forum
Z head
Spuds
10-12-2004 15:20:33
Knowing that a ZA (206)LP head can not be found what is the diff from a normal head and a lp head? how much further does the lp head go into the combustion chamber than a non lp head?
Has any one built up a stock head to lp spec or beyond? Great Idea for a pulling motor!
Thanks Spuds
Kelvin
10-12-2004 18:01:29
 Re: Z head in reply to Spuds, 10-12-2004 15:20:33
Basically, the lp head fills about all the space not needed for the valves to open. I don't think you can go much further on the l-head, without filling in the blocks themselves. If you do that, 'breathing' problems become likely, since you need a certain amount of open area to get the air/fuel from the intake port into the cylinders.
Have you tried Welters? 417-498-6496. They advertised some lp heads a while back.
