Minneapolis Moline Tractors Discussion Forum
R generator circuit
Roger M
10-10-2004 16:02:14
I am in the process of restoring a 1945 "R". It had a generator cutout on it, however it would not start, no power to the coil circuit. The wiring diagram that I have only shows two wires to the generator, one to the battery terminal on the cutout and the other to the field terminal on the generator.
I then installed a new 6 volt positive ground voltage regulator on the generator, the tractor starts and runs with no problem, however it does not charge at all. Whenever I short across the the "B" and "F" terminals the generator charges to what appears to be a maximum charge.
Any suggests are apperciateed.
Thanks
Roger
Bob M
10-11-2004 07:44:23
 Re: R generator circuit in reply to Roger M, 10-10-2004 16:02:14
Roger - Take a look at my reply to Aaron above - I meant to post it here! ...Bob M
