Minneapolis Moline Tractors Discussion Forum
38 inch outside rims on a 445
Joe Z
10-10-2004 04:24:07
Can you still get outside rims for 38 inch rear tires. Do you have to find them new or used? I have the original center hub and cast iron center I lacking the outside rim, one of my tires has a completely different rim, and the other tire has the original.
Kelvin
10-11-2004 18:16:13
 Re: 38 inch outside rims on a 445 in reply to Joe Z, 10-10-2004 04:24:07
If you have what I call the "drive plate" with the 9 lug bolt holes in it, You can probably get a new rim from Miller Tire in Wauseon Ohio and weld it on your plate.
John Deere (don't know which model) used almost an identical wheel on some of their tractors. The rims did come in different widths, so measure yours.
I'm running a set of JD wheels on my 'other' ZB.
