Minneapolis Moline Tractors Discussion Forum
Wide Front MM Z?
Glenn FitzGeral
10-06-2004 19:20:24
Die they make a factory wide front Z? Thanks, Glenn F.
SB in AR
10-06-2004 19:50:27
 Re: Wide Front MM Z? in reply to Glenn FitzGerald, 10-06-2004 19:20:24
Yes, a wide front was available on the Z. As a matter of fact there were several available:
ZTS (1937-1947) had a "standard", non-adjustable, fixed wide front
ZTE (1947-1948) had the "extendable", adjustable width wide front
ZTI (1936-1942) had the "industrial", I-beam solid front axle
ZTX (1943) [X = Military] had the "industrial" axle also
ZAS (1949-1953) "standard"
ZASI (1952) "industrial"
ZAE (1949-1953) "extendable"
ZM (1953-1954) [M = Military] "indutrial"
ZBE (1953-1955) "extendable"
Wow, I knew that MM book would come in handy. :)
Also if you want to see a picture, try the link.
Glenn F.
10-07-2004 11:16:23
 Re: Wide Front MM Z? in reply to SB in AR, 10-06-2004 19:50:27
Thank you very much. Very interesting. Glenn FitzGerald
