Minneapolis Moline Tractors Discussion Forum
Gas vs. Diesel Blocks
Mopower
10-04-2004 05:24:15
Can anyone tell me if there were differences in gas and diesel Jet Star blocks? I know they are same bore, but what else? Would a gas block hold up on a diesel or are the diesel blocks thicker or something?
BMG
10-04-2004 17:04:32
 Re: Gas vs. Diesel Blocks in reply to Mopower, 10-04-2004 05:24:15
Ethan,
You're talking 206 engines here right? I can tell you the busted block in our Motrac diesel appears to match exactly with a gas block. The diesel heads have the same bolt pattern as gas. The Motrac parts book lists the same cylinder part # for both gas and diesel.
Brian
P.S. Boy you should have seen the coolant in that G900. It looked like mud it was so brown. Glad I checked it before winter. It definitely wasn't maintained much in the last 20 years I bet.
