Minneapolis Moline Tractors Discussion Forum
M Hornick more about kt
philmar farm
09-29-2004 19:51:45
I looked at the tractor today. The manifold doesn't appear to be adjustable. The casting number is ke8214. The head casting number is ke251c. The fuel tanks are two seperate tanks,one small,one large. The fan belt is flat and about 2 inches wide. The air cleaner is located on the right[as you sit in the seat] rear of the engine. The air cleaner is about 3 inches deep and 9 inches in diameter. This cleaner is a 'siplex air cleaner' manufactured by 'donaldson'. thanks
M Hornick
09-30-2004 21:18:18
 Re: M Hornick more about kt in reply to philmar farm, 09-29-2004 19:51:45
The style fuel tank that you have was used up to tractor # 300588, after that they have one large two compartment tank. The manifold # is KT 821, the 4 should be a letter. If you could check your block, some had only one 1/8 drain valve, others had a 1/4 inch drain valve and 1/4 inch pipe plug. All have KE 188 for the part #.
Have you checked the motor #?? There is not a tag, but it is stamped into the cast. If I remember, it is under the oil filter. It sounds like you have a early KT, 1929 or 1930. Flipping through the parts book, some changes were made after about 83 tractors were built. Then a run of about 500 were built. At this point more changes were made. Sounds like you are in the first 583, just not sure where.
Hope all this rambling helps. Mike
