Minneapolis Moline Tractors Discussion Forum
Need Some Info On MM Tractor
Jacob Stafford
09-24-2004 14:03:21
Hi my grandpa asked me to find some info on his tractor. Its a Minneapolis and has the #'s 3-5/8x5 206B4. Ive been looking around but cant seem to find anything. Any help would be great. Thanks Jake
Tim Wilson
09-25-2004 07:20:48
 Re: Need Some Info On MM Tractor in reply to Jacob Stafford, 09-24-2004 14:03:21
Jake,
The 3-5/8 x 5 is the bore and stroke of the engine. I believe the 206B-4 was used on the ZA series in 1949 and continued until the ZB came out with a 206G-4 engine. Look on the right hand side of the transmission case and you should find the chassis serial number, and that will identify the tractor.
Brain
09-24-2004 15:25:12
The 206B number represents the size and type of motor. I'm not sure what the 3-5 represents.
Try to find a MM serial tag near the back of the tractor near the operator's seat. On some models, it was attached to the transmission.
If none of this is available, try to describe it. (colors, tires on the front axle close together or spread apart or just one tire in the front, approx weight). Take a picture and put it in the "optional image" portion when posting on this board.
