Minneapolis Moline Tractors Discussion Forum
585/504 changing to direct injection?
Mopower
09-23-2004 08:12:29
I was told there is a fella that machines 585 heads to accept regular injectors eliminating the fuel cells in a 585 motor. Who is it? How about 504?
JK2
09-23-2004 20:57:19
 Re: 585/504 changing to direct injection? in reply to Mopower, 09-23-2004 08:12:29
I should have also added to my last post that I just had a set of heads off a 1370 case & set a MM 504 head gasket on one to see how things lined up. The Case heads are about 1 inch shorter than the MM 504 head & very few bolts would line up. The case engine is direct injection but has flat top pistons.
The cam is on the left side of a 585, the same as a 504. The bolt layout on a 585 is considerably different from a MM 504 & the valves & cam lobes are arranged differently (585-IEIE or EIEI, 504-EIIE)
John
JK2
09-23-2004 20:45:58
585's are direct injection amd have no energy cells. They use pencil type injectors and have cavities in the top of the pistons.
John
Andy2
09-23-2004 17:24:49
I've heard rumors of reworking case heads for MM pullers but never seen one.
