Minneapolis Moline Tractors Discussion Forum
magneto drive
dlp
09-22-2004 18:09:45
I"m wanting to put a mag on a 206 engine. I figure the tower shaft that drives it might be different. Is it different & are there any other changes that I need to make? Thanks!
dlp
09-24-2004 17:59:19
 Re: magneto drive in reply to dlp, 09-22-2004 18:09:45
I found out that the gear on the tower shaft & the gear on the cam are different than in a distributor engine. I want a mag so I can ditch some weight by deleting the battery, starter, & battery box. I want to get it down under 3500#, so I'm deleting as much as possible. I am going to need both gears, mine are rusted to badly to use.
MMark
09-25-2004 05:47:04
 Re: magneto drive in reply to dlp, 09-24-2004 17:59:19
Sorry About the post I wrote I went braindead for a minute. R and Z mags spin crankshaft speed, distributors spin camshaft speed. So you will have to change the gears. 24 tooth on the cam, 12 on the oil pump shaft. I work on so many JD mags I opened my mouth before my brain. JD 2 cyl mags spin camshaft speed. So you can interchange distributor to mag or vise-versa.
Sorry about the confusion,
Mark Damewood
Kelvin
09-23-2004 17:58:31
You have to change both the oil pump drive gear on the camshaft and the oil pump shaft. If you have distribuitor ignition, they both have 16 teeth. For magneto ignition, the drive gear on the camshaft will have 24 teeth and the driven gear on the oil pump shaft will have 12 teeth. (So the oil pump shaft will turn twice as fast as the cam. This helps the magneto produce a good spark at low rpm.)
The oil pressure relief might have to be adjusted-the pump would now spin twice as fast as it used to.
As far as the shafts themselves, there is no difference, aside from the above mentioned gear ratios.
O.K. I'm curious-Why are you wanting to do this?
Kelvin
09-23-2004 18:01:40
 Re: magneto drive in reply to Kelvin, 09-23-2004 17:58:31
Whoops! forgot to mention that in most situations, you will also have to change to a distribuitor drive coupling at the top of the oil pump shaft.
Why do I say most situations? -There may be a few distribuitors out there that were supplied with a coupling that fit the magneto coupling on the oil pump shaft.
Mopower
09-23-2004 04:53:15
You might take a look at the cam gear that drives the shaft. I think it is different as well.
MMark
09-24-2004 06:17:07
 Re: magneto drive in reply to Mopower, 09-23-2004 04:53:15
I may be wrong here, but doesn't a mag and a distributor spin the same rpm (1/2 the rpm as the crank) The impulse on the mag does two things it retards the spark so you don't get kicked when you hand crank and it springs the mag through faster to aid in low rpm firing of the mag. There should be no difference in the cam or oil pump/mag/dist gears. The distributor mounts to what looks like the backside of a mag. I think all you need to do is to remove that distributor mount and (I believe) the oil pump shaft has to be rotated 90 degrees, if you don't the mag wont line up to the correct mounting lugs. (there is one less coupling when using a mag, hence the 90 degree difference) There may be a different drive lug for mag verses distributor but I don't think so.
Mark Damewood
Heath
09-26-2004 15:08:44
 Re: magneto drive in reply to MMark, 09-24-2004 06:17:07
I just completed converting my 1940 R from magneto drive to distributor drive so I cound then install electronic ignition inside my Delco distributor. I have all the parts for the mag drive if you need them. Will sell them to you reasonably - just e-mail me at [email protected]. I'll tell you what, I've never seen a 6 volt tractor start so quick(it's freshly overhauled too). I'm a believer! Here's how I changed mine out....with the mag/dist. off the tractor, start by dropping the oil pump which is bolted to the bottom of the crankcase. When you get it off, firmly pull the gear off of the bottom of shaft. The gear is held on the shaft by two small woodruff keys. It took a little work to get mine out. When these are out, look at the front of the crankcase under the fan mounting, and you will find a set screw. Remove it by backing the nut off and use a large slotted screw driver to back set screw out(I had to remove my radiator to get good enough leverage and room to work). Next I removed the large engine side cover and valve covers. Remove rocker arms. Remove camshaft by taking the four bearing caps off(take note of the way they came off, because the top of the bearing caps have grooves to allow oil to run in from the top). I then put the cam on the bench and heated the gear to drive it off. Then I put camshaft in the deep freeze for a couple of hours(the next day) to shrink it before I drove the new gear on. After shrinking, the gear drove on firm, but not hard. I didn't heat the new gear. Don't forget to re-install the washers and bolt on end of cam. When you re-install cam, there should be about .003 clearance between the gears and the front bearing cap. I had to heat and adjust mine after I got the gear on and test fit it. Be sure to allign your timing marks when you put everything back together. Also, the slot in the drive coupling should be parallel with the crankshaft for magnetos, and cross-wise with the crankshaft for distributors when on TDC #1. When you re-install the oil pump, you are supposed to use 4 paper gaskets together for the right fit, which I did. I used high-tach sealant between each layer to prevent oil leaks. I put everything back together like I took it apart. Don't forget to re-tighten the set screw in front again. The only thing I'm disappointed in now is I seem to have valve float at higher RPMs. I should get all new springs and change them out. They are pretty easy to change on these tractors. Does anyone have any suggestions on a good replacement spring for an R or Z? My machinist used 350 Chevy valves in the head. Maybe those 350 springs would work too?
