Minneapolis Moline Tractors Discussion Forum
G B LP Problem
Irv Plitzuweit
09-20-2004 07:13:37
I drove my MM GB LP about 6 miles to a threshing show. Drove over on vapor and things were fine. (tank was about full) 3 days later its time to drive it home and it started on vapor but died, so turned on liquid. (temp is about 80 deg F) and it would run only with choke full pulled out. Liquid tube and strainer were completely covered with frost. Live in S E Minn and weather was clear and low humidty. With choke out, speed and power were limited, but made it home O K.
Any ideas? Did someone do something to tractor during show?? All help appreciated. THANKS
MMSTEVE
09-21-2004 19:28:49
 Re: G B LP Problem in reply to Irv Plitzuweit, 09-20-2004 07:13:37
COULD THE FILTER POSSIBLY BE CLOGGED ESPECIALLY SINCE YOU DROVE IT HOME WITH THE CHOKE OUT?
STEVE
Curt Cooke
09-21-2004 06:06:25
You have an obstruction in your fuel supply line somewhere. There will be no frost ahead of the problem; the frost will occur at the problem and after. I'd take the short amount of time and check to see that ALL lines were free of obstruction from the tank to the vaporizer.
