Minneapolis Moline Tractors Discussion Forum
Hydraulic Level Jet Star 3
DOK
09-18-2004 06:03:12
I recently put a loader on my Jet Star 3. What is the proper method to make sure I have the correct amount of hydraulic fluid in the tractor. I raised the boom half way, extended the bucket half way, and raised the three point half way. Then I filled to the fill line on the dip stick. I appreciate any help offered.
John Kinsey
09-19-2004 05:57:05
 Re: Hydraulic Level Jet Star 3 in reply to DOK, 09-18-2004 06:03:12
The book says everything the 3 point should be down. It doesn't say anything about a loader.
When I fill my JetStar3 Super, I leave everything down & fill to line on dipstick.
If you are having trouble with it jerking or hear air in the system, check all the connections between the resevoir and the pump inlet (the big line). The pump creates suction on inlet & filter assembly & will draw air through connections even though no oil leaks out.
