Minneapolis Moline Tractors Discussion Forum
Head gaskets
Brent
09-16-2004 17:59:40
What is the best way to put on a head gasket? I"ve been told to`put them on dry,use paint, use gun greese and even soak them in water over night. What do some of you do? Thanks for any ideas. Brent
deadeye
09-19-2004 03:29:50
 Re: Head gaskets in reply to Brent, 09-16-2004 17:59:40
I used a thin coat of coppercoat sealer on U"s, G"s and anything larger....deadeye..JB
Kelvin
09-16-2004 18:03:16
If I can get some, I put a thin bead of Permatex#2 around the water holes on my head gaskets. On larger MM heads, (U,G) I also run a bead around the outside edge. I find that they tend to seep oil on the pushrod side if you don't gunk them there.
