Minneapolis Moline Tractors Discussion Forum
painting an old plow
Brian(MN)
09-08-2004 18:53:45
hi, Have any of you guys done any research into the colors used on the MM plows from the forties and fifties? Was it the same as they used on the tractors? I am cleaning up a 2-16 solid mold board plow that is on rubber. A friend tells me he thinks moline used a slightly different paint on their impliments. I think moline probably used the same paint just applied less of it. Plows almost always sat outside so it did not last long anyway. If I don't learn anything new I'll paint it MM prairie gold and red anyway. I was Just wondering if any body else has thought about this.
Brian(MN)
Hoss
09-08-2004 20:29:01
 Re: painting an old plow in reply to Brian(MN), 09-08-2004 18:53:45
The colors are the same. The only dfference being that the implement is red and the wheels are Prarie Gold, just the opposite of the tractors.
Alan
09-08-2004 19:23:16
As far as I know they used the same paint as on the tractors. Most all literature from that era
I believe shows the same. Someone was also making the "MM Acme Steel" decals on the back of the moldboards. I may have some plow lays if you need some. Also have a trip rope holder which you might like to have for plowing.
Brian(MN)
09-08-2004 20:43:49
 Re: painting an old plow in reply to Alan, 09-08-2004 19:23:16
Thanks for the information guys. who has those MM acme steel decals? and also on the back of the moldboard is a yellow MM decal . Does any body make them?
Brian(MN)
Kevin Moschenrose
09-09-2004 00:02:32
 Re: painting an old plow in reply to Brian(MN), 09-08-2004 20:43:49
The place to get the decals is R-M distributors. If you send me a email I can send you a copy of what they have and a phone number.
Brian(MN)
09-09-2004 06:44:10
 Re: painting an old plow in reply to Kevin Moschenrose, 09-09-2004 00:02:32
Hi, I quess I should look in my corresponder before asking. They have what I am looking for.
Thanks, Brian(MN)
