Minneapolis Moline Tractors Discussion Forum
206 engine compression problems
Tyler
09-05-2004 19:11:16
does anyone know what compression (in psi) an MM 206 engine with a RE226c cylinder head should have? any help would be great.
MMark
09-06-2004 19:36:03
 Re: 206 engine compression problems in reply to Tyler, 09-05-2004 19:11:16
With a stock bore around 135 to 155 psi. Should be around 6.1 to 6.2 comp ratio.
MMark
Tyler
09-08-2004 18:21:53
 Re: 206 engine compression problems in reply to MMark, 09-06-2004 19:36:03
Do you happen to know what the approximate compression in PSI would be for a 206 engine that has a 180 thousandths over bore and flat top pistons? Sorry I forgot to mention that it was punched out.
Tyler
