Minneapolis Moline Tractors Discussion Forum
MM POWER UNIT QUESTIONS
david smith
09-02-2004 22:05:38
Hello folks i just located an mm power unit today i was wondering what it was worth on the tag on the right side of the frame it says it is a MOdel HUA and serial #70832 with a 4 5/8" bore and 6" stroke it is a 6 cylinder engine i have a U Power plant and it looks pretty small compared to this one it is all complete and it isnt stuck i was wondering what to offer im for it it says TWIN CITY MM on the radiator so i figured it must be fairly old thank you very much
BMG
09-03-2004 09:56:43
 Re: MM POWER UNIT QUESTIONS in reply to david smith, 09-02-2004 22:05:38
David,
You've found an early 605 power unit. I'm guessing mid 1930's vintage. It's prior to 1940 as the HE engine came out in 1940 and I think it was the replacement for the HUA. Value depends on where you are located. Up here in Michigan stationary MM engines seem to bring more money than say for example those located in southern states and further out west. They're harder to find up here unless you have them trucked in and that's where they get expensive. LW may be right for his part of the country at $200. Up here that engine may be worth $500 or more.
Just my opinion.
LW
09-03-2004 08:19:17
$200 at the most
