Minneapolis Moline Tractors Discussion Forum
MM Z R water pump seals
Larry R
09-01-2004 17:27:06
Where can I get them.
Kelvin
09-01-2004 18:53:57
 Re: MM Z R water pump seals in reply to Larry R, 09-01-2004 17:27:06
Welters 417-498-6496 or Everetts 740-922-3335 should have them.
If your baffle is bad (or gone) they will have these too.
also: If you get bushings, make sure they have grease holes in them, or drill some yourself. (The last set Welters sent me didn't have them, so I drilled my own.) Then be sure you align them with the grease cavity in the housing.
