Minneapolis Moline Tractors Discussion Forum
MM ZAS
K. T. Novak
09-01-2004 06:47:44
I have inquired in the past about the possible production numbers of a MM ZAS with Live power but with little luck. Can anyone give me a ruff idea of the possible production numbers of such a tractor and what the tractor may be worth. Thanks for your help in advance.
K. T. Novak
09-02-2004 08:03:02
 Re: MM ZAS in reply to K. T. Novak, 09-01-2004 06:47:44
Thanks a lot Kelvin. Mine is a 53 according to the SN number but the breaks are on the left side and there is a drum break on the right side. Kelvin, are the conversions common? I haven't seen any on a Z yet so i gotta wonder. A U i worked on had a similar conversion but that is all i've seen.
Kelvin
09-02-2004 17:42:01
 Re: MM ZAS in reply to K. T. Novak, 09-02-2004 08:03:02
Actually, I have never seen a converted ZA of any wheel configuration that had live power. There was one in the Antique Power magazine 7-8 years back. The owner still had the instruction sheet for the conversion.
There was a converted U (about a 1950 model) at a show here in NC one year. It still had the brake drum on the right side.
I also own a 1954 UTS (diesel) that had life power which I presume is factory. It has the disc brake housing on the right side too. the brake pedals are on the right side also.
Kelvin
09-01-2004 19:18:12
This is what I think:
If your ZAS has disc brakes on both sides and both brake pedals are on the right hand side determined from facing the rear of the tractor, it most likely has factory "live power". And it probably is a 1953 model.
There was a kit offered that allowed conversion of other ZAS, ZAU, etc. to live power as well, but it was a field conversion. and most if not all retained the drum brake on the right as well as both brake pedals on the left hand side.
As far as I know, there are no production numbers for ZAS with live power, just as there is no data on which ZAS received lp gas equipment.
I asked 2-3 years ago if anybody had a ZA with brake pedals on the right and came up zero.
