Minneapolis Moline Tractors Discussion Forum
Seal on PTO shaft
JoeZ
08-31-2004 18:24:42
My 445 is leaking oil from the PTO shaft.Is there a oil seal that belongs on the shaft. There are 2 tapped holes (3/8-16 or 1/2-13) near the shaft. There may have been a cover of some sort orginally. Was the seal in that cover?
Kevin Moschenrose
08-31-2004 22:45:32
 Re: Seal on PTO shaft in reply to JoeZ, 08-31-2004 18:24:42
No, Those tapped holes is where the PTO gaurd bolts on at. The seal is behind the dust cover that is tack welded or crimped onto the pto shaft itself. Once that is removed you will have access to the seal and can be renewed then. You don't need to remove the PTO shaft.
