Minneapolis Moline Tractors Discussion Forum
G-V1 diesel
Changeover
08-28-2004 08:35:50
Wanted to know what part of a diesel motor can i use if i want to change over to gas.Want to make a puller out of it.
Andy2
08-29-2004 14:09:21
 Re: G-V1 diesel in reply to Changeover, 08-28-2004 08:35:50
You would have to put gas or LP heads,and intake manifold on it and remove the center head bolts. The diesel crank, rods and pistons are very heavy, way heavier than you need for a gas engine.
Mopower
08-30-2004 05:24:42
 Re: G-V1 diesel in reply to Andy2, 08-29-2004 14:09:21
A diesel does not have an opening to run a governor in the crankcase. Plus your cam would be way off. It would be easier and much cheaper to go get an old 605 power unit. They are good compression and horsepower and a dime a dozen.
Ethan
p.s. An 800 would work, but vore expensive!
MO Man
08-30-2004 10:27:10
 Re: G-V1 diesel in reply to Mopower, 08-30-2004 05:24:42
Mopower I will take 3 dozen of 605's I have never seen any very cheap. I do run 1 in my Puller. Real Pulling tractors do not run governers so the 605 crankcase is not any problem, also we buy cams that are designed to work with all the changes such as RPM levels 4 to 5000 rpm are common. To put it plane old MOlines make good pulling tracors with the main bearings being the weakest link. But do it anyway!! Think about a complete engine package before you start.
Mopower
08-30-2004 10:49:50
 Re: G-V1 diesel in reply to MO Man, 08-30-2004 10:27:10
I didn"t know what type of pulling this GVI would be pulling in. It is real nice to see a MM running as strong as your 4-5000 rpm. I pull speed limit classes so maybe a 605 will end up in my GBD, but more likely to do a 585. Probably fairly stock RPM. There are a few 605 around, but not sure what "cheap" is. My rules might prevent a diesel to gas conversion.
Ethan
MO Man
08-29-2004 17:41:07
Change head to LP get a big intake, carb and starter you will need for extra compression from diesel pistons. See my reply on G1000 puller also
MIB
08-29-2004 19:21:00
 Re: G-V1 diesel in reply to MO Man, 08-29-2004 17:41:07
Why would flat top diesel pistons have that much more comp than the lp pistons with little or no dish in them? They came either way.
MO Man
08-30-2004 10:30:37
 Re: G-V1 diesel in reply to MIB, 08-29-2004 19:21:00
4232 heads and flat tops should give you around 11.5:1, big starters are sure nice when that motor is warm.
Andy2
08-30-2004 13:03:06
 Re: G-V1 diesel in reply to MO Man, 08-30-2004 10:30:37
4232's on a 425 6 cyl with flat tops would give you around 7.2:1 and 145-165 lbs compression. Source: MM cylender head specification chart.
Changeover
08-30-2004 12:14:54
I know where a diesel is coming up for sale, the only way I'm intested is to make a puller out of it. But the pulling rules around here you have to have a woking governer.I dont know how well a diesel would pull.Wanted a lp or maybe gas. Maybe could swap engines without to much trouble. Just needed help to make up my mind.
Andy2
08-30-2004 13:07:16
 Re: G-V1 diesel in reply to Changeover, 08-30-2004 12:14:54
If it runs good, pull it without doing anything. low gear or speed limet class you may not need more power. There are easy upgrades for the diesel: blocks and pistons from a G-705,G-1000 This gives you 504 cubes. with a biger intake you can get 110+ hp pretty easy.
RD
08-30-2004 14:18:29
 Re: G-V1 diesel in reply to Andy2, 08-30-2004 13:07:16
Will a G-1000 INJECTION PUMP work on a Gvi
MO Man
08-30-2004 19:25:31
 Re: G-V1 diesel in reply to RD, 08-30-2004 14:18:29
I have a 504" G705 complete and together, sounds like that might solve your changing parts problems. It would make a good starter Pulling tractor for 1st gear or RPM pulling just like it is. It needs tires other than that you could go pulling quick and CHEAP and kick BUTT.
Mopower
08-31-2004 07:23:22
 Re: G-V1 diesel in reply to MO Man, 08-30-2004 19:25:31
MO Man,
If you"d like some pretty affordable 605 motors I can get you as many as you need.
Ethan
