Minneapolis Moline Tractors Discussion Forum
Super Honkin UB Special
MagMan
08-24-2004 09:19:01
I went to the local pull this weekend and I finally got to see my neighbor pull his Ub special Or I guess thats what it is anyways. He cleaned house from 7500# to 10,500# Classes In stock and inhanced. The only thing that beat him was a suped up JD G that had about $10,grand into the motor And that was in just one class. I wish you all could have seen the pull very exciting. JON
Mopower
08-24-2004 12:16:39
 Re: Super Honkin UB Special in reply to MagMan, 08-24-2004 09:19:01
Sounds pretty special to me MagMan. Used to have a diesel. Very neat tractor. What do you suppose was in the contraption? Get any head or carb numbers?
MagMan
08-24-2004 13:04:11
 Re: Super Honkin UB Special in reply to Mopower, 08-24-2004 12:16:39
This is what I do know stock gas block. It may have a little stroke. Uses it to plant with a good size no till every spring.As far as heads go who knows he has a whole field full of those yellow tractors and its hard to tell what he has on it.What motor the carb came off not sure either it did have electronic ign though.The next time I talk with him I will feel him out a little. He is the type that will tell if you ask. JON
Mopower
08-24-2004 13:09:43
 Re: Super Honkin UB Special in reply to MagMan, 08-24-2004 13:04:11
I have seen lots with MM. Just curious because he was pulling heavy weight. I have a G motor U and a Z motor R. Even working on a U302 motor J. I pull a G motor UB. My UBD has G900 blocks on it. My tractors are mild. M670 heads and 5-3/4" X 7" bore and stroke are out there all over. Like to hear people tryin"! I stay bigger but fairly stock M-M parts.
Ethan
MagMan
08-24-2004 13:45:05
 Re: Super Honkin UB Special in reply to Mopower, 08-24-2004 13:09:43
Cool" I like the red ones my self But I am interested in knowing about all of them. Any size or Color. JON
