Minneapolis Moline Tractors Discussion Forum
will a 220 power unit motor fit in a z
pete
08-21-2004 17:46:25
will it bolt in and what clutch assembly will work thanks Pete
Mopower
08-22-2004 07:40:03
 Re: will a 220 power unit motor fit in a z in reply to pete, 08-21-2004 17:46:25
Petey Petey Petey, what have you got going on now? Haha. Let me know what you find. I think I have a good starter flywheel combo for my JT and the 220. You going ZT instead? How did you find your 220? I don"t really know how many there are around. I have 1 and 1/2.
Ethan
JK2
08-21-2004 19:42:18
Pete,
I don't think you would have any trouble bolting the engine in BUT the flywheel/starter is a problem. The 220 PU uses a three bolt starter and the flywheel & ring gear are made for it. The Z uses a slip in starter with bigger teeth on both the bendix and ring gear. I think the Z flywheel will work fine & you could make an adapter that bolts on with 3 bolts to use the orig Z starter, maybe on 12 volts.
You could also use a 206 from a 445 etc with the Z flywheel & maybe bore it to 220 if you wish or even use the blocks, pistons, rods & heads from the 220 on the 206.
John
Kelvin
08-21-2004 19:39:02
I've seen a picture of a ZB with an overhead valve engine in it. And I've given it a little thought but never done it.
Which model Z do you have? A ZT has an RE engine and the ZA and ZB have a 206 engine.
If you have a ZA or ZB, you use the tractor's flywheel and clutch. It may have to be modified for a later style starter ring gear, for the ring gears used on the overhead valve tractors are a different part number. (unless you can use the tractor's original starter.)
If you have an RE engine, you have to use a 206 flywheel (The RE flywheels fit a splined shaft. The 206 flywheel fits 2 dowels and mounts with 4 bolts and should fit right on the 220 crank. (The dowels in the crank may be too long, don't know.)
The other issue that quickly presents itself is the water pump inlet on a 220 is on the opposite side from the Z radiator. If you have a ZA or ZB, you can't just move the radiator outlet: The cast lower tank is only "Dipped out" on the left side.
I've also looked at the 220 water pump. I first thought just make a new mount plate and rotate the pump, but that won't work because the flange of the pump has a cast recess that allows water to flow back into the tube that leads into the front block. This area only lines up in the stock position.
