Minneapolis Moline Tractors Discussion Forum
Jetstar 3 ampli-torc question
HH
08-19-2004 18:34:01
My question: Can the ampli-torc Drive be removed permanently from the tractor? And if it can what goes in its place.
I know I will loose the high and low range option. But for my tractor use I don't need this option.
Thanks in advance for your help!
HH
Bill Stinson
08-24-2004 16:46:52
 Re: Jetstar 3 ampli-torc question in reply to HH, 08-19-2004 18:34:01
I have a similiar problem with a M602 "Ampli-Torc". The low range went out about 10 years ago, and we just kept using it. Recently, it suddenly stopped, and I think the high range went out, but I am not sure. There are kits to convert some Oliver tractors to direct drive, but I don't know if there is such a thing for MM. I'll let you know if I learn more about it.
Kelvin
08-20-2004 18:52:54
Some industrial tractors had a reverse shuttle.
I don't know this for fact-but I expect some industrial applications just had a 5 speed.
I'm guessing you're taking this tractor 'pulling. Can't figure why you'd want to take it out unless you want to get rid of a little weight. Otherwise just tighten the clutch and run on the high side, like I do.
Wayne Snelling
08-19-2004 22:58:27
I feel like I am intruding here but the Jet Star 3 caught my attention. I am looking at an LP model JS 3 and it has several missing parts, like one is the water pump. Can anyone give me a parts supplier or have any parts? I may need the hood?
I could not find any info on production of different JS 3 models can anyone steer me to that info, if it exists.
jim w
08-20-2004 09:42:29
 Re: Jetstar 3 ampli-torc question in reply to Wayne Snelling, 08-19-2004 22:58:27
A good parts supplier is : Wendell Everette in Gnadenhutten Ohio. 740-922-3335....jim
Wayne Snelling
08-20-2004 22:59:58
 Re: Jetstar 3 ampli-torc question in reply to jim w, 08-20-2004 09:42:29
Thanks Jim I"ll try Wendell. Looks like I may need to held get a 445 going as the water pump just started leaking and may need some seals/bearings for it also.
Thanks again.
Wayne
