Minneapolis Moline Tractors Discussion Forum
585 question
MM
08-15-2004 10:15:27
was the 585 ever built with a turbo? or any aftermarket setups? will they bolt right into a G900-1000? any pulling advise for useing one of these motors?
thanks
L Klingler
08-20-2004 08:02:40
 Re: 585 question in reply to MM, 08-15-2004 10:15:27
You should be able to DOUBLE your STOCK HP. (even a little more) on allmost all motors! The 585ci will take 350hp.
I Know
08-19-2004 17:47:50
Danny Gray from Pleasant Hill,MO pulls a hot farm G-1350 MM diesel that must be making 400-500 horses.He may have a block girdle to hold the crank in place.
Its pictured on page 23 of the 2004 July Hook magazine in the Belgrade,MO tractor pull ad.It runs pretty good.
James1
08-17-2004 13:08:00
Advice is to be very careful. The MM engine had only 4 mains. Typically a 6 cyl should have 7. If the crankshaft is beefy enough, the fewer bearings would not be a great problem. The MM crankshaft was strong, but not enough for the cyl pressures that adding a turbo and fuel for much greater hp would cause. A turbo for altitude normalization is OK, it allows you to maintain hp at higher altitudes. At lower altitudes it does little, just along for the ride. The MM engine was a great gas engine. The bottom end was just a little marginal for hp much above stock in the diesel version. Other diesel problems were: not big enough (thick) top/compression ring (would break around 3 to 4 thousand hours, and the pistons also needed an iron band for the top land ring.
Phil Munson
08-17-2004 20:39:36
 Re: 585 question in reply to James1, 08-17-2004 13:08:00
It is true that the minnies only had four mains, and many others had seven. It is also correct that there were lots of other sixes that only had four mains. The Minnies, however are the only ones I know about that had FOUR bolt bearing caps; not crossbolted. They are a very large bearing. We had a 504D that turned the meter without building the engine, others only made a few thousand hours. It is how you use it and care for it. Some guys can break a crowbar.
As with any engine, especially souped up ones, an overdose of fuel, lugging, and general abuse can do them in.
David
08-16-2004 09:50:22
My uncle had an A4T-1600 with a turbocharged 585. The thing ran like a beast if you could keep it together, which wasn't very often. I remember it spending more time down than actually in the field. It was a factory kit, but I don't know if it was factory or dealer installed.
Mopower
08-16-2004 05:16:15
I know a G1000 Vista running a 585 turbo for pro-stock pulling classes. Pretty hot stuff.
Pistol Pete
08-15-2004 18:31:01
Yes the a few of the 585's were turboed from the factory. The last 75 of the A4T1600's were sent to Denver to be equipped with an "altitude compensator" (turbo) for farming the high plains. Of those 75, 50 of them were bought by Oliver and called the 2655. If my memory serves me corretly about a conversation w/Bob Hawks, M&W never made a kit for the 585. Don't know about anybody else. As for the last part of you question, I do not know.
Minni
08-20-2004 10:47:57
 Re: 585 question in reply to Pistol Pete, 08-15-2004 18:31:01
does anyone know where I could find an exhaust manifold or any info on the turbo setup?
thanks
