Minneapolis Moline Tractors Discussion Forum
rear cranckshaft oil seal GBD
dave K
08-13-2004 12:09:43
IS IT NECESSARY TO INSERT THE SHIM GASKETS WHEN CHANGING THE REAR CRANK OIL SEAL, OR WILL THE GAP CAUSE THE TWO PIECE SEAL TO LEAK OIL?
Kelvin
08-13-2004 19:26:09
 Re: rear cranckshaft oil seal GBD in reply to dave K, 08-13-2004 12:09:43
If its made like a 283 or 403, and is a 2-piece felt, if you don't shim the retainer, you'll have to dope the oil pan gasket so the gasket itself won't leak back there.
Is the crank in, and is the crankcase in the tractor?
dave K
08-15-2004 12:48:31
 Re: rear cranckshaft oil seal GBD in reply to Kelvin, 08-13-2004 19:26:09
yes the crank is in and the crankcase is in the tractor, seal doesn"t seem tight enough to the crank and is slightly leeking!
