Minneapolis Moline Tractors Discussion Forum
MM445
Ted Regentin
08-08-2004 17:54:18
I am looking for some information about an exhaust manifold on my 445. It is leaking where it joins the intake manifold. It seems to be rivited together. I have an I&T manual, but it doesn't cover the manifold. Has anyone run into this? If so, what is the fix? Also there are two studs that come out of the heads to mount the manifold. One is broken off. Will it come out? Thanks in advance. This is a great resource.
Ted Regentin
Donnie
08-08-2004 19:08:29
 Re: MM445 in reply to Ted Regentin, 08-08-2004 17:54:18
What you are calling rivets are actually bolts either 3/8" or 5/16" can't quite remember but just got done restoring one and had the same problem. You can either take them to a machine shop to have them redone or even do it yourself if you have the time and patience to do it. Just don't get in a hurry!!!! There is supposed to be a gasket in between the intake and exhaust manifold. The studs in the heads should be the same way. Any more questions let me know. Donnie
