Minneapolis Moline Tractors Discussion Forum
G1000 LP with HD800
Sponz
08-03-2004 19:37:20
ok.. now i know a little about this scenario..
i know that a G1000 rear end wasnt the best in the world,, and i know a 800 has some SERIOUS POWER.. but i have heard of people running 605's and all they did was put a cooler on the rearend and make some oil ports larger.. now what i'm curious is.. if i enlarge these ports.. add a cooler and run a synthetic oil do ya'll think i'd get along alright as long as im sensible??
IF this is insane please tell me Thanks Sponz
freddy
08-04-2004 07:44:00
 Re: G1000 LP with HD800 in reply to Sponz , 08-03-2004 19:37:20
First if you use a late model G1000 vista or G1050 rear end they are quite a bit heavier in the rearend gears, like an inch wider. If you can find an antiwear additive that won't mess with the torque it would probably hold up good. Great idea for an A4T-1400 or 1600. would of added years to the trannies. Of all the junk tractors at the salvage yards i've seen over loading and over ballasting have cause serious pealing of the gears. although not many of them are blown up. Not anymore than John Deere, IHC or Case, etc, etc. A lot of your high performance gear boxes use antiwear or antiscuff additives, with out them they just turn into junk.
john.k
08-09-2004 19:41:29
 Re: G1000 LP with HD800 in reply to freddy, 08-04-2004 07:44:00
my cousin currently has my fathers old g1000vista 504ci turbo charged on dyno 368hp for every day use it"s 18000lbs and over 18 years never had a problem with rear end, tourqe,tranny and that is well over 100hp of a stock hd800 p.s worlds finests tractor period no ? asked 20 years ahead of their time.
MIB
08-09-2004 20:28:42
 Re: G1000 LP with HD800 in reply to john.k, 08-09-2004 19:41:29
A stock HD 800 is about 240 hp the 504 was rated at 120.
