Minneapolis Moline Tractors Discussion Forum
bosh psb injection pump
fireguy
07-29-2004 07:08:17
I reciently purchased a 1954 gtbd moline, if anyone has any information on this tractor feel free to email me at [email protected]. the problem i am having is that when i crank over the engine the injection pump is not pumping fuel to the injectors, the transfer pump works good, but there is fuel running out the lube oil fitting on the bottom of the injection pump housing.
dang duy thanh
04-12-2006 19:43:22
 Re: bosh psb injection pump in reply to fireguy, 07-29-2004 07:08:17
i want to se the catologe anh parameter of psb injection fuel
Tramway Guy
07-30-2004 19:18:39
Sounds like you need a new "hydraulic head" for the pump. It contains the pumping element and distributor. You can do it yourself if you are careful.
