Minneapolis Moline Tractors Discussion Forum
G900 Minneapolis Moline Diesel Tractor
Kim MacDougall
07-28-2004 07:56:22
Have a problem with the hydraulics. Been baling for a few days everything working fine. Went to tie a bale and the hydraulics quit half way through the tieing. Have no hydraulics on either lever now. Any ideas.
dale foland
08-03-2004 00:55:52
 Re: G900 Minneapolis Moline Diesel Tractor in reply to Kim MacDougall, 07-28-2004 07:56:22
same problem with 670, open center. closed center would be different altogether, right? okay, have 1750@8gpm, 3 point squeals at full lift, new oil, new filter. is it still the relief valve under seat.
KS
08-02-2004 12:23:11
First question is does the three point hitch work?
Have you checked your fluid level?
When did you last change the filters or the fluid?
I dont know if the rate controls on the platform by the back of your right foot have anything to do with the remote spools, but you can check to see if they have been moved.
Just a few things to check,
KS
freddy
07-30-2004 10:11:33
open center or closed center hydraulics?
Shep VA
07-30-2004 11:00:49
 Re: G900 Minneapolis Moline Diesel Tractor in reply to freddy, 07-30-2004 10:11:33
G-900 should still have open center hydraulics. I think the first closed centers were on the G-950.
Jim C
07-30-2004 14:34:58
 Re: G900 Minneapolis Moline Diesel Tractor in reply to Shep VA, 07-30-2004 11:00:49
My G900 has closed center system sn 33101698.
Heath
07-30-2004 19:16:10
 Re: G900 Minneapolis Moline Diesel Tractor in reply to Jim C, 07-30-2004 14:34:58
Just for clarification, a few G900s in late 1968 and all of '69 production had closed center hydraulics. I believe it was introduced on the 1969 model year, but Dad's 900 s/n 33101331 has closed center and shows in the list as a 1968. However, he bought it as a 1969 when it was new.
1206SWMO
07-30-2004 22:33:16
 Re: G900 Minneapolis Moline Diesel Tractor in reply to Heath, 07-30-2004 19:16:10
In late 1968 a neighbor bought a new 1968 G-900 MM.Shortly thereafter the 69's came out and he wanted the new closed center hydraulics so he traded off the 68 G-900 with only 17 hours on it for a new 69 G-900.We promptly traded our 670 MM for the 17 hour G-900.It was a very dependable tractor.
