Minneapolis Moline Tractors Discussion Forum
Gb LP crank pully
mikes'600
07-25-2004 13:19:27
Will the pulley slide off after the set screw is removed using a gear puller?
I want to advance the timming one tooth,will this give me some bottom end performance gains ? Do you people think i'am wasting my time? Thanks Mike
Andy
07-26-2004 20:20:57
 Re: Gb LP crank pully in reply to mikes'600, 07-25-2004 13:19:27
you can have the cam ground for lugging for about $250,(berry cam); it's money well spent if you are going to pull it. If you are going to use it in the field I wouldn't advance the cam or have an overly aggressive grind because you can burn valves and have higher egt's.
Captainhookerus
07-26-2004 19:20:44
Mike remove the set screw then unscrew the crank nut off end of crankshaft. Then with a steady straight pull the crank pulley should come off. I have found one tooth advance to be worth while. Also check that both crank gear and cam gear have not partially sheared off their woodruff keys.
Ken
TedMM
07-26-2004 05:34:14
You migth have to heat it to get it off without breaking it.
YES IT WILL HELP. You will be surprized how much it will help.
Kevin Moschenrose
07-25-2004 14:07:32
I think you are wasting your time. I would look at other choices besides that one.
