Minneapolis Moline Tractors Discussion Forum
Minneapolis Mol;ine 220 engine
DOK
07-23-2004 16:38:49
What applications was the MM 220 cubic inch engine used for? I am aware of the Jet Star 3, forklift, and stationary power units. Any others? Thanks.
JK
07-24-2004 07:04:21
 Re: Minneapolis Mol;ine 220 engine in reply to DOK, 07-23-2004 16:38:49
The JetStar3 has a 206 engine not a 220.
The 220 used in a Big Mo 400 M (military) uses different bearings and the blocks are a different height than a normal 220 used in U302, power units and forklifts. John
Mopower
07-25-2004 07:03:52
 Re: Re: Minneapolis Mol;ine 220 engine in reply to JK, 07-24-2004 07:04:21
I think I have an M220 power unit. Maybe HD220. Not sure. What is the block number, what is the difference in blocks, and why are they taller?
JK
07-26-2004 14:21:43
 Re: Re: Re: Minneapolis Mol;ine 220 engine in reply to Mopower, 07-25-2004 07:03:52
I don't know why the Military blocks are taller. I just know that my father put a set on his U302 & could never get a reasonable amount of power from it. When we took it apart, the pistons didn't come to the top as they do on a normal 220 engine. Replaced the blocks & pistons with normal 220 ones & it is fine.
I'd have to go look for the block number on the Big Mo 400. The U302 block should be 11A20903.
The M220 in my Big Mo 400 has a slip in style starter instead of the 3 bolt starter used by the 220 engines in the U302.
John
ian watkins
04-07-2006 11:50:39
 Re: Re: Re: Re: Minneapolis Mol;ine 220 engine in reply to JK, 07-26-2004 14:21:43
i have a minneopolis mol 220 engine it has been rebuilt but not started new top end and etc i would like to learn more about this motor but having a hard time finding info and what it is worth your help would be much thanked
Kevin Moschenrose
07-23-2004 23:08:39
Big Mo 400 military
Andy
07-23-2004 20:01:34
U-302
