Minneapolis Moline Tractors Discussion Forum
is this a lp head
John
07-20-2004 09:41:51
I have mm gb with 10a 4209 heads on it is this a high compression lp head? some one had the same heads on ebay listed as lp heads off a mm u. thanks John
Andy
07-21-2004 07:19:30
 Re: is this a lp head in reply to John, 07-20-2004 09:41:51
It would be high compression on a GB/403 but it is not what was used on LP's. That would be 4210,4213. It was not a LP head on a U either; someone may have converted a U to LP and left the gasolene heads on it. It would be a great head on your GB, good compression and power but you could still burn regular gasolene.
moline
07-20-2004 19:36:01
John,Go to Jeremy Fiorello's MM pulling site.He has the head charts for MM listed with compression ratios.The 4209 head will fit on a 403 (g engine) and a 283 (U engine)but the compression will be different.There is also a fellow on here by the name of Andy that is very sharp on the MM heads and blocks.Hope I was of some help to you! Moline
