Minneapolis Moline Tractors Discussion Forum
Jetstar 2 diesel wide front with MM loader
Chris
07-04-2004 15:29:47
Hello and I hope that someone can tell me the true value of my tractor. It is a 1962 MM jetstar 2 diesel with wide front and MM loader. it has all the sheet matel and runs strong. power steering and very heave three point hitch. shuddle shift trans andautomatic depth control on the 3 point hitch. It also has a set of origenal MM cast wheel wieghts.
Thank you for any help that you might give.
Mopower
07-06-2004 08:33:14
 Re: Jetstar 2 diesel wide front with MM loader in reply to Chris, 07-04-2004 15:29:47
Your Jet Star Two should be a 1963 because that was the only year they were made I believe. Is the original paint yellow sheet metal and brown engine. If so, you could have a nice collector piece there. Our Jet II is a gasser and I would not trade it for anything. Yours should be worth $3500 I would guess...depending on rarity...which I would rate very high being a Jet II AND a diesel.
