Minneapolis Moline Tractors Discussion Forum
r puller needs advice
potter
06-27-2004 13:43:13
want advice from someone who has pulled an r, I am very light in front end so I am going to put a weight bracket on front, how much weight can I put on the front without hurting my traction I filled both tires with beet juice and have one mm wheel weight on front and at the end of pull my front end comes up real high and then I spin out.
thanks Potter
Mike
07-02-2004 18:01:59
 Re: r puller needs advice in reply to potter, 06-27-2004 13:43:13
Where do you get the beet juice from,they only do cloride around me as fare as i know.
peter
07-02-2004 19:04:20
 Re: Re: r puller needs advice in reply to Mike , 07-02-2004 18:01:59
beat juice came from Michigan sales in Marquette Michigan (906) 225-0500
Mike Logan
06-27-2004 13:53:00
drawbar out, drain the juice and put as much up front as you can
