Minneapolis Moline Tractors Discussion Forum
Minn Moline...RT 100
EJ
06-26-2004 18:31:07
I am looking at what I believe is a RT 100 with factory cab and duals. The glass in the cab is gone...and there is NO rear door...it is gone. The tractor sheetmetal and cab metal look good. It has sat for a 'Long Time' outside. I am not sure, at this point, if the engine turns or not. How does one determine the aproximate value of this tractor? I am aware that it is a 'good' collectable tractor, but I want to be fair to both the seller and myself, as a possible buyer. I would appreciate ANY advise. Thank you. EJ
steve
07-01-2004 19:32:20
 Re: Minn Moline...RT 100 in reply to EJ, 06-26-2004 18:31:07
Not many people respond to this question hard to judge without being there. It sounds like you have an RTI or industrial version with an Allied cab Not worth the thousands that an R-cab is worth but very collectable, I would like one. Look for serial # tags-one on side of engine is just for engine-one on side of transmisson is for tractor and should say RTI RTU RTE or RTS right on it. If you find tractor serial # you can look in guide for year, RTU with factory cab only made first couple of years 38 to 40 maybe.We used to figure not over 500 if it didn't run but things are going up and the cab makes it worth more, depends on how bad you want it.Look on this web site for pictures of R-cab and RTI w/cab or UTI w/cab for comparison Good Luck
