Minneapolis Moline Tractors Discussion Forum
MM ZA
wrayski
06-21-2004 12:41:04
Does anyone know how I would stop a slow oil leak at the pto lever, also can you overfill the radiator, I'm a newbie to tractors and the guy who sold me the tractor told me he had just overfilled the radiator and it was coming out of the cap when running...
JC
06-21-2004 18:52:27
 Re: MM ZA in reply to wrayski, 06-21-2004 12:41:04
You may need to tear down the rear end and re seal. In the meantime, if it is just a drip now and then, you may want to change the rear end oil (it needs to be done anyway)and add some Lucas Oil Fortifier or similar "gum up the works" product. It won't stop the leak, but it may slow it some. I suggest getting a good shop manual that details putting new seals in.
Yes, you can overfill a radiator, that is what the overflow is for. If it leaks a bunch out, see if the radiator has a hole. If it pushes a bunch out the top, I would suspect a blown head gasket allowing air into the system and the pressure is pushing the water out.
If it leakes a cup or so out and then stops, your OK.
I suggest checking the fluid level oil, water, rear end, and greasing your tractor before you use it. It takes 5 minutes and makes your tractor last almost forever!
Good luck and welcome to the Moline bunch!
wrayski
06-22-2004 09:17:08
 Re: Re: MM ZA in reply to JC, 06-21-2004 18:52:27
thanks...JC
