Minneapolis Moline Tractors Discussion Forum
Big Mo 400 front wheel hub
ken davis
06-19-2004 10:10:32
mine broke! I need to find a replacement, my question is what models use the same parts as the 400M? I have the dual wheel gas model made for the military, year is 1959... thanks so much kd
Kelvin
06-19-2004 19:54:47
 Re: Big Mo 400 front wheel hub in reply to ken davis, 06-19-2004 10:10:32
The hub-the part the wheel bolts to-is the same part number as a jetstar. Since its the same part number as a jetstar, you can use a hub off a 445, 4star, jetstar, jetstar2, jetstar3, jetstar3super, and some 335s equipped with heavy duty hubs.
If you really mean the spindle-the part that the hub& bearings goes on, has a vertical shaft that the steering arm turns-it has a different part number if its a Big MO 400 Military from my jetstar parts catalog.
I guess I'm questioning your post because I can't figure how a hub that heavy duty on that small a tractor can break.
ken davis
06-19-2004 20:14:27
 Re: Re: Big Mo 400 front wheel hub in reply to Kelvin, 06-19-2004 19:54:47
Great info, Kevin, thanks alot! Te hub broke because I modified a Case front loader to the Big MO and we were hauling rock from a foundation excavation, figured the load was around a ton, probably wouldn't have broken had I put machine bolts all the way thru from the back of the hub and then thru the new 1/2 plate that supports the heavy split rim tire that carries a jet fighter tire. As it was, the shorter lug bolts seem to have backed off and created a void allowing the edge of the hub to fracture. Serious case of operator error as far as overfilling the bucket that I had expected to never fill but the excavator did the loading rather than the Mo under its own power. I also added a torque converter into the steering shaft so it has power steering, its a nice rig. Thanks for the info on the interchangeable parts, now, where can I find one or two! kd
John G
06-21-2004 19:41:24
 Re: Re: Re: Big Mo 400 front wheel hub in reply to ken davis, 06-19-2004 20:14:27
I've picked up #3000 with my Duall loader on my BigMo 400. Got regular 16" tires on it, 6 ply, the only way you know when the limit is reached, the rearend comes off the ground. Got fluid and 2 sets of rear weights on it, picked the Cummins out of a big truck, had to have 2 guys stand on the drawbar to move it, NO PROBLEM!!!!
Kelvin
06-21-2004 19:07:21
Everetts: 740-922-3335
Don Rice: 585-243-2617
Welters: 417-498-6496
Kelvin
06-21-2004 19:09:14
 Re: Re: Re: Re: Big Mo 400 front wheel hub in reply to Kelvin, 06-21-2004 19:07:21
You know that's a pretty rare tractor to be cutting up like that, don't you? Save all the pieces-Someday somebody would be glad you did.
