Minneapolis Moline Tractors Discussion Forum
41 Z Bubbles in radiator
steve
06-15-2004 19:07:31
Almost done restoring my Z now suddenly I'm getting bubbles in radiator. Someone else started the restoration then the tractor set for years so I didn't do engine. Where am I most likely getting compression leak? There is a little seepage around cylinder to block connection but doesn't seem like there would be pressure there. How about head gasket is that more likely? I mention tractor sitting because other gaskets seem to have dried and shrunk and I find myself redoing everthing the previous owner had done. Thanks in advance for suggestions
BMG
06-16-2004 14:59:06
 Re: 41 Z Bubbles in radiator in reply to steve, 06-15-2004 19:07:31
Steve,
If the previous owner forgot to tighten the cylinder head to the blocks before tightening the blocks to the crankcase then there's a good chance the head gaskets are not sealing. If this step wasn't done then the head is not sealing flat to both blocks. I also like to put a small amount of silicone sealer around the water ports on the head gaskets to be sure they seal well.
Brian
Kelvin
06-15-2004 19:14:07
about the only place you can get combustion pressure in the water-other than through a crack in the block or head- in those engines is through the head gasket.
