Minneapolis Moline Tractors Discussion Forum
403/605 Diesel
Mopower
06-15-2004 10:45:19
Would any M-M experts out there have any information on a 403 or 605 diesel engine? I have an ad showing a 605 diesel power unit and I know M-M made some 403 diesels at the factory with counter balancers in the crankcase. None are confirmed to be released to the public, but you never know. In fact a straight eight was prototyped too. Anyone? Info? Stories?
kevin
06-15-2004 21:42:05
 Re: 403/605 Diesel in reply to Mopower, 06-15-2004 10:45:19
I have seen a 605 diesel myself . they are kind of old. they say the 585 diesel was prototype from one. if a 065 diesel was made it probably would not be that hard to make a 403 diesel fron a old 605 diesel. just my 2 cents worth. never heard of a straight eight but why not. just another block. I have heard of half of a 336 propane made for the oil industry.
Mopower
06-16-2004 04:39:47
 Re: Re: 403/605 Diesel in reply to kevin, 06-15-2004 21:42:05
Hi Kevin. Where would I find a 605 diesel? I guess they had mechanical issues but I'd love one for my GBD. It would look more correct than a 585.
Kelvin
06-16-2004 20:05:17
 Re: Re: Re: 403/605 Diesel in reply to Mopower, 06-16-2004 04:39:47
I couldn't resist adding to this thread:
There was a guy-Dave Neubert near Monroe NC who rebuilt a GVI as an 800cu in.
I was thinking it was diesel at one time-but maybe that was before the rebuild. The last time I saw the tractor at a pull it was on gasoline.
A.P.
06-18-2004 06:07:56
 Re: Re: Re: Re: 403/605 Diesel in reply to Kelvin, 06-16-2004 20:05:17
Dave's tractor was originally a diesel. He ran it that way for a while. Not sure how big that engine was but it ran very nice and had a lot of bottom end grunt. The 800 was just a starting point for the cubes once he went to the gas engine.
A.P.
Mopower
06-18-2004 04:54:08
Quite possible. 585 with 800 crank gets you 650 cubes. I do not know how things hold up when you start stroking a diesel and going wild. If you got the cash, lots of combinations are neat ideas. I'm a cheap son of a gun, but maybe one of these days.
kevin
06-16-2004 11:07:07
The one I seen was at the kansas state fair as a display for some rebuilder company. It was a lanova type diesel. I have never came across another one since but I will look around for one now if you would like. There were MM's at Husker Harvest Days in Grand Island, Ne also I can look there also.
Mopower
06-16-2004 11:39:49
 Re: Re: Re: Re: 403/605 Diesel in reply to kevin, 06-16-2004 11:07:07
That's good Kevin. If you ever happen to see one let me know. They may have had a weak gas crank or head gasket problems according to some, but more or less a misfit that never really caught on I guess. The 425, 451, 504, and 585 were the standard diesels and if anything more than that was needed, propane engines were probably used.
Dieselbear
06-16-2004 15:01:19
 Re: Re: Re: Re: Re: 403/605 Diesel in reply to Mopower, 06-16-2004 11:39:49
I am running a 674 cu, Diesel in my GBD. It's one sweet running tractor. I run 20.8/34, Firestone 23 degree tires. Can run 4th up to 9000, and only running about 1900rpm
Mopower
06-17-2004 06:21:50
 Re: Re: Re: Re: Re: Re: 403/605 Diesel in reply to Dieselbear, 06-16-2004 15:01:19
Hi Dieselbear. I've chatted with you before on diesels. Sounds like you got a strong one there. My latest theory was using a 585 with 800 crank/rods. It all fits. Might not look quite stock. Yours still holding together? Any problems? Maybe just a dream of mine, but sounds good....sounds expensive. Just saw the add for a 605 diesel and thought hey that would look good if there are any out there.
Dieselbear
06-19-2004 14:54:03
 Re: Re: Re: Re: Re: Re: Re: 403/605 Diesel in reply to Mopower, 06-17-2004 06:21:50
Everthing is working great so far. Been running this tractor for about 4 years. Runs great, pull as high as 13500, ran out of places to put weight!We have been run out of alot of places, But we have fun
