Minneapolis Moline Tractors Discussion Forum
Carb Swap
JC
06-14-2004 01:29:20
Will an early 1950's UTS carburator fit and work on a 1948 ZTU?
Thanks!
Kelvin
06-15-2004 19:20:18
 Re: Carb Swap in reply to JC, 06-14-2004 01:29:20
It won't bolt up to the manifold. throttle shaft is on the wrong side, and also uses a larger diameter throttle rod. Its jetted for 283 cu. in, A 48 Z is 206 cu in. (stock) so you probably would have fuel mixture problems too.
What you need is a Marvel Schebler TSX 97.
