Minneapolis Moline Tractors Discussion Forum
Brakes on a 445
Joe Z
06-09-2004 10:12:25
Has anyoneone changed the brakes on a 445 MM ?
Mine has no brakes at all and I have no idea how big of job it is to change them.
The reason is the tractor split now after rebuilding the engine, and I don't want reassemble the engine just to find out I have take it apart again to put on brakes.
Thanks for your help!
G. L. Perry
06-14-2004 10:55:27
 Re: Brakes on a 445 in reply to Joe Z, 06-09-2004 10:12:25
No split, BUT, keep in mind if all oily from leaking seal in that area on the bullshaft, you will need to pull full assembly out and repair, or new brakes will be ruined shortly and grab bad with oil on them. The shims there also adjust the bull pinion play, be carefull not to mess that up and don't bend shims, very thin some of them. The change is in an IT book, the same for most models of MM's with those disc brakes. Get your brakes revovered at a brake shop. Mine were done, no grooves in them, they worked oK w/out the grooves.
SWMolines
06-09-2004 20:28:27
The brake discs are behind the round covers below the platform. Just in front of the rear axles. They can be repaired without splitting the tractor.
