Minneapolis Moline Tractors Discussion Forum
U Starters?
G Brown
06-06-2004 06:25:43
What is the difference besides the drive on a 1951 U starter? Can the drive be changed on a 1107905 to make it a 1107977? When did the 12V system first used on a U? I'm in the process of rebuilding 1951 UTE and have no starter or no generator. Any help would be appreciated.
Kelvin
06-06-2004 19:34:59
 Re: U Starters? in reply to G Brown, 06-06-2004 06:25:43
My book info is incomplete:
As far as I know, the drive is the only difference between the two starters. Of course, there would be a diameter difference in the ring gear on the flywheel, too.
I can tell you that the 1107905 drive has ten gear teeth. I have no info on the 1107977.
One way to get around this is if you can come up with the earlier 1107905 starter AND the right flywheel/ring gear combo.
My aftermarket book says the 12v starter 1107605 was in use '53-55.
Kelvin
06-06-2004 19:32:53
