Minneapolis Moline Tractors Discussion Forum
Steering on a Z
Shep Va
06-01-2004 12:23:37
My 1950 ZAU narrow front tractor is getting a lot of play in the front end. I replaced the U joint on the steering shaft and tightened the nut at the steering box and the nut between the two tires, and all that is now tight, but I still have almost a half a steering wheel of play. The steering shaft going into the box is not moving back and forth at all, but it is turning a half a turn. This gets to be a problem going down the road as the front wheels want to wobble back and forth real fast and will almost shake the wheel out of your hand.
I guess my question is what in the front end could be loose or worn causing this??? Is the steering shaft connected to the worm gear with a pin or something that could be worn or do you suppose the gears themselves are worn out?? Any Ideas, Im sure out of them?? I guess the next step is to tear the entire front end apart and see what is going on in there.
Steve
06-01-2004 17:30:37
 Re: Steering on a Z in reply to Shep Va, 06-01-2004 12:23:37
To inspect the gears remove radiator and grill and under them is a steel plate covering the worm and sector gears. You should be able to see the problem then. Good Luck
Shep Va
06-02-2004 05:00:49
 Re: Re: Steering on a Z in reply to Steve, 06-01-2004 17:30:37
Thanks Steve. Is it normal for those gears to wear out and create that much play??? This tractor had a loader on it most of its life, but does not any more.
Thanks again.
John M
06-02-2004 16:24:37
 Re: Re: Re: Steering on a Z in reply to Shep Va, 06-02-2004 05:00:49
Could you please keep us posted when you find the problem and solution? I have a 48 ZTU with the same problem. I would like to know any info before I tear into it. Will do the same if I find time to work on mine before you.
Thanks.
JM
Shep Va with a pic
06-03-2004 05:25:38
 Re: Re: Re: Re: Steering on a Z in reply to John M, 06-02-2004 16:24:37
third party image
Sure, be glad to tell you what I find. I dont know when I am going to get to it though, my Z is busy running a 4 basket tedder right now. Also I am afraid if I take that radiator off it is going to start leaking, it is not in the best shape, so when I tear into it I need to be prepared to have the radiator re cored. I was hoping I could fix the problem without messing with the radiator but it doesnt look like it. I really need to fix the wobble before something breaks and runs me off the road, but if it is just wear in the gears it should not break I suppose.
Thanks for the help guys
