Minneapolis Moline Tractors Discussion Forum
800HD question
Eddie
05-24-2004 19:09:15
Late model 800hd with full circle rear seal is there a problem putting this motor in a G6 moline or do you half to use the old style rear seal motor?
LW
05-25-2004 15:59:00
 Re: 800HD question in reply to Eddie, 05-24-2004 19:09:15
I have a flywheel for sale that will bolt this engine in a GVI or like tractor.Yes a one piece seal flywheel for a tractor with hand clutch.
Eddie
05-25-2004 20:33:12
 Re: Re: 800HD question in reply to LW, 05-25-2004 15:59:00
LW what are you asking for the flywheel??
LW
05-27-2004 19:11:50
 Re: Re: Re: 800HD question in reply to Eddie, 05-25-2004 20:33:12
55lb lighter than stock , balanced,$500
Curtis
05-25-2004 10:20:27
You have to use the old style rear seal motor. I believe the problem is the crankshaft flange is different and you can't use the GVI flywheel. If you had a flywheel solution I believe you could use the motor.
