Minneapolis Moline Tractors Discussion Forum
Low oil flow on half of valves on UB gas
Irv Plitzuweit
05-22-2004 16:26:16
Put new rings and rod bearings and had valves ground and 4 replaced. Now when running with valve covers off I have very little flow to the rear half of the valves. I removed the tube (about 12 inches long) and checked for constrictions or plugs and it was fine. Any suggestions? I would guess oil flow was low before I worked on partial overhaul, but don't know. Thanks for any suggestions.
Kelvin
05-22-2004 18:19:29
 Re: Low oil flow on half of valves on UB gas in reply to Irv Plitzuweit, 05-22-2004 16:26:16
Irv, put the tube back in, don't hook it to the rocker arm, see if you have any flow through it. If not, the restriction is in the crankcase. If you have flow there, the restriction is in the rocker arm itself. Its hollow and sometimes fills up with goop.
