Minneapolis Moline Tractors Discussion Forum
UB Generator Wiring
John UB
05-20-2004 12:18:00
Hello,
I'm trying to get my UB ready for a local plow day and need to hook up a new generator I purchased. The old one was never hooked up, so I'm not sure how to do it.
Can somebody tell me what wire goes where? I believe the field wire on the regulator goes to the field post on the generator, but after that I'm lost.
Thanks for all your help!
John
Tim
05-21-2004 09:13:08
 Re: UB Generator Wiring in reply to John UB, 05-20-2004 12:18:00
John,
I also have a UB. Although mine is a UBE. It pulls like an ox.
Here is a link to something that helped me even though it is for a green and yellow tractor. My brother has a JD40.
Link
Let me know if it helps.
Tim
John UB
05-21-2004 09:31:12
 Re: Re: UB Generator Wiring in reply to Tim, 05-21-2004 09:13:08
Tim,
Thank you for the link. I think between everybodies comments and your sketch, I should be able to figure it out.
Thank you everyone for the help!
John
Kelvin
05-20-2004 19:44:52
Word pictures are hard, but here goes:
Yes, a wire goes from 'F' terminal on the regualator to the 'F' terminal on the generator
your regulator is a 'saddle' type, right?-It mounts on the generator itself. If so, There should be a terminal on the bottom that connects to the armature post on the generator.(sometimes marked "A").
A wire from the 'Bat' post on the regulator goes to the ammeter. (It usually works right if you hook to side opposite the +). Two wires come off the other side of the ammeter. One goes to the starter push button, the other goes to the same post on the starter solenoid that the NEGATIVE battery post is hooked to. (The system is positive ground.)
The reason the starter button is powered like this is that it can pull 40amps or more when engaging the solenoid and it would peg a 30 amp gauge otherwise.
A wire from the 'L' terminal on the regulator goes to the 'BAT' terminal on the 5-position ignition switch.
A wire from the 'IGN' on that switch goes to the coil +.
For the lights, you're on your own. I usually have to poke around with a test light until I figure out how the resistors work.
Don't forget to polarize the generator. I can't remember which posts to cross with a wire, though.
Polarizing generator
05-21-2004 05:22:42
 Re: Re: UB Generator Wiring in reply to Kelvin, 05-20-2004 19:44:52
After making sure your wiring is correct per Kelvin's instructions, polarize the generator (actually, it is polarizing the regulator), by MOMENTARILY shorting a piece of wire between the 'batt' terminal on the regulator to the 'gen' or armature terminal of the regulator. As you pull the wire away after the momentary short, there should be a little spark. This is normal and indicates that you've properly polarized the generator.
Be sure to avoid touching the 12 volts from the 'batt' terminal to the 'field' terminal of the regulator or your regulator will be toasted.
John UB
05-21-2004 05:21:42
Kelvin,
Thank you for responding. My regulator is a saddle type, but I think I only have three posts on the regulator. They are L, BATT, and F. The system is positive ground.
Thanks again for your help and it should get me going.
John
