Minneapolis Moline Tractors Discussion Forum
bronze paint on a zb
roger hinton
05-19-2004 19:52:43
How much bronze paint was used on 1954 zb? I'am now restoring a zb and have sand blasted a lot of bronze paint off under the parie gold. was this an after thought by the factory or did this tractor come from the factory this way?
DH in Carolina
05-22-2004 10:53:06
 Re: bronze paint on a zb in reply to roger hinton, 05-19-2004 19:52:43
Roger Go to: www.minneapolis-moline.com and click on paint codes. This may answer your question.
AZ Jack
05-19-2004 21:17:14
I expect what you are seeing is the primer under the prairie gold.
roger
05-20-2004 18:59:50
 Re: Re: bronze paint on a zb in reply to AZ Jack, 05-19-2004 21:17:14
It sure looks like bronze paint but it is not everywhere just on the transmission and brakedrums
none on the sheet metal or engine.
Kelvin
05-20-2004 19:49:28
 Re: Re: Re: bronze paint on a zb in reply to roger, 05-20-2004 18:59:50
Its most likely a red oxide primer. If you look inside the brake housings (your ZB really has disk brakes, doesn't it?) you'll probably see a good coat if it. It was probably painted inside the transmission, too.
roger
05-21-2004 15:14:27
 Re: Re: Re: Re: bronze paint on a zb in reply to Kelvin, 05-20-2004 19:49:28
No it's not red primer and you are right it does have disk brakes and inside the housings there is red primer. This is bronze paint I thought possiably some previous owner might have done this But this was under the steering colume as well. also the centers of the rims have a cockshutt look with the eight spoked attachments instead of the pressed wheels. I know I have a basket case.
