Minneapolis Moline Tractors Discussion Forum
4213 heads
mmguy
05-17-2004 06:41:03
just came onto a 1950 UTE LP in a shelter belt. has 4213 heads on it. didn't catch the block #. I assume this has been hopped.any info on this???Where can I get a listing of what heads are used on what model??? Thanks ,Jim
Mopower
05-17-2004 08:52:50
 Re: 4213 heads in reply to mmguy, 05-17-2004 06:41:03
These heads were used on some of the LP gas U tractors and maybe a few UBs too. More commonly, LP gassers had 4206 and 4207 heads. The 4213 was also used on quite a few gasoline machines including the 5-star. It was a little higher compression for maybe a higher altitude. My friend has one gas UB with 4213 and it runs very clean and smooth. 7.55:1 ratio in a stock U/UB and 9.9:1 on a G engine. I don't think your engine has been modified unless it has big blocks on it. I would stick to the 4213 heads. There is a link to the head data lists on www.minneapolis-moline.com. I believe Jeremy Fiorelli's website has the list. Hope this helps! E-mail me ([email protected]) if you need more data. I can send you the head list with all the specs in a word document. Very easy to look at.
