Minneapolis Moline Tractors Discussion Forum
mm G1000 pto instilation
Jeremy Dickey
05-05-2004 07:37:59
I am looking at purchasing a MM G-1000 wheatland and it has no pto. Is it very hard to install a pto or can it even be done and if so are the parts too hard to find. I helped my grandfather install one on a case with same problem years ago. I need the pto to run a bailer or I have no need of the tractor. Just wondering if it would be worth the trouble. Thanks for the input Jeremy.
errol
08-08-2006 22:50:50
 Re: mm G1000 pto instilation in reply to Jeremy Dickey, 05-05-2004 07:37:59
Hi ran into the same problem do you need to split the tractor to install?
jeremy
05-10-2004 08:16:56
thanks john just what I need to know.
John Crandall
05-09-2004 07:43:01
I have installed a pto in a G1000 Wheatland but it is a big job. The best way to do it is to purchase a parts tractor (possibly with a blown engine) that has a pto and use the complete backend or to remove the pto parts and install them into your tractor. Hope this helps.
