Minneapolis Moline Tractors Discussion Forum
GB pto attachment
Roger
04-22-2004 20:45:30
Is the pto for a GB that bolts on the back end the same as one for a U or UB? Thanks
Kelvin
04-23-2004 05:54:14
 Re: GB pto attachment in reply to Roger, 04-22-2004 20:45:30
I'm 99% sure the housing that bolts to the rear of transmission case is the same. The shaft that runs up to the lower transmission shaft may or may not be, and for that we need to compare part numbers.
Roger
04-23-2004 06:49:55
 Re: Re: GB pto attachment in reply to Kelvin, 04-23-2004 05:54:14
Thanks Kelvin, it looks like the bolt on housing would be the same but wasn't sure, but it wouldn't surprise me the shafts are different.
Andy
04-23-2004 15:08:14
 Re: Re: Re: GB pto attachment in reply to Roger, 04-23-2004 06:49:55
They should be the same. The easy way to put one in is to park the tractor down ditch so you don't have to drain the gear lube.
